External oil boiler fault
29 Sep 2026
Hi, we had a Grant's vortex Pro external combi 26 oil boiler installed in July 2024. Approximately 3 weeks later we noticed that the boiler was coming on by itself and would sometimes be on for hours before we noticed. The thermostat (a Center RF wireless thermostat) was not calling for heat, was set to OFF and was set to manual. It's been happening on and off ever since, sometimes with large gaps of time between occurrences.
There is no identifiable pattern to when this happens, it does not occur at a particular time a day and does not seem to be related to cold temperatures as it has happened when it has been warmer.
Some notes that might be relevant, the last time the boiler was came on by itself, we went to the room where the boiler receiver is, the thermostat was set to off and no flame symbol was showing. However when we clicked the on/off button on the thermostat, the boiler receiver was making clicking on off noises.
The fitter recently replaced the thermostat with a new one but it's happened again. He now suggests getting a hive system but I'm not sure that will help.
Any help on this would be greatly appreciated, thank you for reading.
One thing to check would be a link fitted at the pcb. Not sure about Grant/oil boilers, but vast majority of gas boilers have these fitted. Often overlooked by lots of engineers.
Maybe one of these Links?
Sounds like wireing issue.
The Grant external combi's should be feed by a 5 core.
Permanent live, switched live for hot water, switched live for heating plus neutral and earth.
If your competent with mains voltage and have a multimeter easy to check.
Unplug supply cable take lid off plug .
Correct sequence is on page 22 of installation manual.
As well as your rf stat you should have some sort of time control for the hot water as required by building regs.
Should also add the boiler has 2 separate methods of frost protection which can cause boiler to run.
Great, thank you, that's super helpful.
So what do you think of the recommendation to get a hive thermostat system?
As you have had original rf stat changed and problem remains difficult to see how swapping to hive would cure anything.
When problem occurs checking with a multimeter will quickly establish where stray live is coming from.
Worth checking flow switch is working correctly multimeter again.
Assuming your boiler was commissioned by a Grant registered engineer and has a correct service history it's got a 10 years warranty.
If nessarary get your installer to speak to Grant technical they will walk him through required checks.
I've found them excellent in sharp contrast to some other oil boiler manufacturers.
Ok cool, again really helpful, thanks so much!
