    Dismiss Notice
External Pipe Gaurd to protect plastic pipe from knocks
Discussion in 'Plumbing and Central Heating' started by swebb99, 15 Apr 2020.
  1. swebb99
    swebb99
    3 Jun 2016
    123
    Thanks Received:
    3
    Country:
    I'm looking for a gaurd/protector/cover for the runoff(?) pipe that comes out of my combi boiler. The pipe comes out of the wall in to my alley way about 2ft off the floor and goes down in to the ground, it's plastic. I'm worried that as some point I will knock it and damage it so I'm looking for a tough cover for it. I'm sure I've seen something similar but I just can't find one on the web, maybe I'm using the wrong terms. Any idea ?
  2. Sponsored Links
  3. Looks well supported I'm sure it would be fine.
    However if you were to box it in with say Batton and a marine ply you could also insulate it the prevent freezing in the winter.
    • Thanks Thanks x 1
    • Like Like x 1
  4. bobasd
    bobasd
    2 Dec 2017
    2,368
    Thanks Received:
    435
    Country:
    Try: Loblite 55mm x 55mm Cable Guard @ TLC.com
    • Like Like x 1
  5. swebb99
    swebb99
    3 Jun 2016
    123
    Thanks Received:
    3
    Country:
    Yes it's well fixed however I move a fair bit of heavy stuff down the side alley so I'm concerned I will smash it off at some point. The cable gaurd might be an idea , that might work however I was really looking for something out of metal to take something heavy smashing in to it.
  6. Tigercubrider
    Tigercubrider
    22 Jul 2016
    4,660
    Thanks Received:
    749
    Country:
    You could knock up a frame from dexion or find a mate with a welder and make something?
    Or use keyclamp and tube. You can get a small bore version
  7. Sponsored Links
  8. bobasd
    bobasd
    2 Dec 2017
    2,368
    Thanks Received:
    435
    Country:
    OP,
    There was no pic showing on my screen when i suggested the obviously unsuitable Loblite Guard. I thought you were referring to a smaller, typical condensate pipe.
    Gas utilities use 2" exposed galvanised service pipes, and sometimes protect them with steel guards similar in shape to the Loblite.
    But where they source them from I dont have a clue?
    Pipefitter Companies might help?
  9. denso13
    denso13
    22 Jan 2007
    5,638
    Thanks Received:
    1,121
    Country:
  10. swebb99
    swebb99
    3 Jun 2016
    123
    Thanks Received:
    3
    Country:
    Thanks for that, the last one looks interesting because they do customer sizes :) That looks like it would be perfect for the job. (y)
  11. Gasplumber
    Gasplumber
    21 Dec 2017
    168
    Thanks Received:
    17
    Country:
    It’s a lot overkill to protect it to be honest. Cost you more time and effort to protect it
    Than fix it you broke it
  12. swebb99
    swebb99
    3 Jun 2016
    123
    Thanks Received:
    3
    Country:
    Yes I was thinking that put the upper and lower part of the pipe are cemented in to the wall and floor and it struck me if either end is damaged it's going to be a pain to fix.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
