External Socket
30 Sep 2005
Hertfordshire
Do all weatherproof sockets require entry from the sides or top or bottom ?
Somehow I imagined that a rear entry wouldn't have been the more obvious, until I looked at one.
would you consider that water runs:
1) downwards
2) sideways
3) upwards
now, I am sure you answer your own question.
It has provision for a drain hole. and out the back isn't that much different to out the side, for which a push out is available.
But I'll take that as none provide a back entry hole then.
i used a weatherproof adaptable box once, and that had 2 rear entries available, i suppose if you chipped away the brickwork (or whatever) behind, you could make room for a gland there.
