External South Facing Sweedoor
21 Nov 2005
Hi-Have a Sweedoor hardwood external south facing door that was not treated regularly with teak oil and was at some point varnished-unsure of the type. As a result of the warmer weather the varnish has peeled and exposed the wood itself, which itself is all very sound thankfully and showing no sign of degradation. The rest of the window frames etc on the south facing side are very good as a result of proper t/c and are a very light mahogany. What is the best way too strip the door, prepare and repaint/treat/stain, so that the theme is continued Any ideas and suggestions greatly appreciated. Kindest regards.
I would go with paint stripper to avoid burning it.
As Zampa says but i would then treat with Sikkens Filter 7, about 3 or 4 coats, good stuff.
Yeh so much better than Sadolin IMO
Thanks for taking the time to respond and for the professional advice-greatly appreciated. Regards
Pleasure...maybe you might want to think about taking the door off and work on it flat..its easier and safer.
Folks - Got the Sikkens Filter 7. Given that I am stripping the door back, do you think I should use HLS? Gonna start this weekend so if you get the chance to reply, would be greatly appreciated. As was stated, the guy in the trade centre states the filter 7 is the, "mutts danglies". Thanks
I would always use the HLS on bare wood. Its the main basecoat or a finish in it's own right. (far better IMO) though more mainenance.
http://www.sikkens.co.uk/en/Product...stain+Systems+-+Traditional+Solvent-borne.htm
on bare wood you should apply one coat of HLS followed by 2 coats of filter7.
Good luck.
Sikkens id far better than Sadolin IMO...lovely finish and easier to use.
Thanks for the prompt responses. Very much appreciated. A tin of HLS it is then! Kindest regards
