extra shelf airing cupboard
7 Nov 2020
Ireland
Would no more nails hold up battens to mount an extra shelf in airing cupboard?
The battens would be attached to plasterboard sides
12mm ply or mdf the length off the side under the shelve support baton sitting on the shelve below fixed with no nails
haven't you got a drill?
if you look at the plasterboard carefully, or use a neodymium magnet, you may be able to find the column of nails showing where the studs are.
