extraction fan
You should trace the bathroom light cable and the bathroom switch cable to a junction box somewhere.
If (for some unknown reason) this is not possible, you will have get the feed from the light AND the switch.
So at the light you can get the switched live and neutral, and at the switch (that junction box you found sounds easiest) you can get the permanent live.
OR
At the light get the neutral, and at the switch (jb easiest) get the permanent live and the switched live.
Don't forget to include a 3 pole fan switch for isolation of the fan.
Okay Thereshow, concentrate on picture no 2 from the last set you posted- you need to find the ceiling rose nearest the one to the bathroom, and hopefully, the one that supplies the bathroom setup. This shows 3 live wires, on in, one out, and one to the switch. As you've only got a live and neutral in the bathroom lights, they've had to set up a junction box, take a live and neutral to the JB, and then take the live down to the lightswitch. The switched live comes back to the JB, and then the switched live and neutral goes to the bathroom light. So from that JB, you need to take a 3 core and earth, pick up the live, neutral and switched live, and take them to the fan isolator, and then to the fan. Correct me if I'm wrong guys.
