Extractor fan in the bathroom not powering off
15 Dec 2006
Durham
Hallo
My extractor fan in the bathroom doesnt power down. It was set to 30 mins but it wont turn off, I have tweaked the timer but again it doesnt turn off. The extractor is turned on via a pull cord. The lights are on a dimmer switch outside of the bathroom so they are seperate.
Any help would be great
Ste
Have you recently fitted or altered it?
(wrong?)
Hi
It has never switched off , to switch off I have to turn it off permanantly
Fans with timers are usually wired so that they are switched on when the lights come on, then the timer holds them "on" for a period after the light goes off. If yours is independent of the light switch then it could not work that way.
Otherwise:
either the timer is faulty; or the incoming live wire is in the wrong terminal.
If you can post a picture of the fan's terminals, showing the connections, that may help. Also say what make and model it is.
Ok thanks John. I will most likely not get chance to look til the morning so I will post as soon as I have chance
Kind Rgds
Ste
