False alarms, air freshener
7 Feb 2012
Somerset
I have had a couple of false alarms in a room that was totally closed. Not had false alarms in there before. Just noticed there is a free standing battery powered air freshener in there. I would not have thought the fine mist would be the problem but just asking if anyone has had any issues with these or any comments ?
andytw
Intruder alarm or fire / smoke alarm ?
Above average amounts of air freshener have been known to trigger smoke / fire alarms. ( manufacturer's in-house and un-published test results ). But these were very high levels far too high for a person to feel comfortable in the room and therefore considered unlikely to be a problem in normal domestic use.
If it is an intruder alarm first get the vacuum cleaner with the pipe adaptor and clean behind and around the sensor?
If it is smoke alarm check battery and possible install date of smoke detector.Also get the vacuum cleaner and pipe adaptor and clean inside the smoke detector and near smoke chamber ? If you still have problem change the unit.
Thanks. It is actually an intruder alarm. The detector is an Honeywell IS-215TQ. I will clean it today and see how it goes.
andytw
