Fan Advice
8 Feb 2004
Wolverhampton
i have just taken off my kitchen fan to clean it and have noticed that it was fitted with the fan wheel at the front (sort of upside down) :oops:
Does this mean it has not been extracting for all these years?
Also the exit hole is at an angle going diagonally upwards. Should I straighten this hole or will it still extract ok ?
Maybe its just the design and it has been extracting correctly. Have you tried the simple test of switching extractor on and holding a piece of paper to the outlet - if it sticks you are ok :D
Do not think that the angle of the hole should affect extraction, however I would suggest that either straight or slightly downwards would be better to allow any moisture to drip outside and prevent water ingress from outside.
