    Dismiss Notice
Fan Vibation on Worcester Bosch Greenstar 18Ri?
Discussion in 'Plumbing and Central Heating' started by macman81, 12 Feb 2009.
  1. macman81
    macman81
    1 Apr 2007
    106
    Thanks Received:
    2
    London
    Country:
    My mother had one of these installed in December. I was there when they commissioned it and it seemed OK at the time. I went to visit her again last week and noticed that there was a deep vibration when the fan starts up. This wasn't constant, only a momentary effect at a certain fan speed as it speeded up. But when the boiler modulated back to that same speed range, the vibration was continual. It seems to originate from the fan area, but vibrates right through the structure, you can feel it even with one hand on the flue. Because she is very deaf she hadn't realised there was a fault.
    I got the installers back, they agreed it was not right but said they would need to get the WB service engineer to take a look. He came last Monday, I wasn't there, but he tinkered with it, muttered something to her about a 'design fault' that he would mention in his report, and left without leaving any paperwork or explaining what he had done or if any further work was required.
    She now tells me there is a continual vibration from it...
    I called the installers again and their response was to ask me to call WB back myself, and that they do not see the service reports produced by WB. I told them that as far as I was concerned our contract was with them, not WB, and it was their responsibility to sort this out, regardless of whether it is a manufacturing or installation fault. Eventually they agreed and the WB engineer is going back next week.
    Does anyone know of any inherent problem with this boiler and should I be doing anything else please?
  2. Sponsored Links
  3. screech
    screech
    21 Oct 2008
    682
    Thanks Received:
    115
    Norfolk
    Country:
    if combustion is out they can be noisy so maybe not set up from the factory which sometimes happens
  4. davebgas
    davebgas
    9 Feb 2009
    2,043
    Thanks Received:
    256
    Nottinghamshire
    Country:
    DIY gas advice not permitted
  5. macman81
    macman81
    1 Apr 2007
    106
    Thanks Received:
    2
    London
    Country:
    So would this not be the first thing that the WB engineer would have checked? What I don't understand is that it was originally only at one fan speed? Now he's 'adjusted' it it does it all the time!
  6. screech
    screech
    21 Oct 2008
    682
    Thanks Received:
    115
    Norfolk
    Country:
    after adjusting it he may have left the pcb set on the wrong setting. when setting the combustion you set the boiler to run at maximum, set the combustion, then set it to minimum and set the combustion, then go back to max and so on until both are within range. the engineer probably left it set to max or min rather than turning it back to its standard operating position.
  7. scatmanjohn
    scatmanjohn
    2 Nov 2005
    3,382
    Thanks Received:
    234
    Country:
    The fans on WB greenstars have a little rubber flap (a non return valve type thing) that can break off and get stuck in the fan and cause it to vibrate,
    Seen lots but usually its after they are a few years old.
  8. Lord Elpus
    Lord Elpus
    28 Mar 2016
    Thanks Received:
    Country:
  9. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,071
    Thanks Received:
    1,080
    Norfolk
    Country:
    The internal vent requires the case to be removed and should not be a DIY job.......Lord Elpus....
    • Like Like x 2
  10. Sponsored Links
  11. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,042
    Thanks Received:
    9,423
    Hertfordshire & London
    Country:
    Especially with such a retarded case design.
  12. Agile
    Agile
    26 Jun 2004
    63,560
    Thanks Received:
    4,511
    London
    Country:
    Surely this is advice for an RGI and not for a DIYer owner?
    In any case any RGI should know where to find that information.
    It seems a totally inappropriate posting!
  13. Agile
    Agile
    26 Jun 2004
    63,560
    Thanks Received:
    4,511
    London
    Country:
    Worcester have a very good reputation for service backup.
    So it is rather unexpected that they will have apparently have not identified the problem, not left any service record and apparently left it worse than it was when they arrived!
    Tony
  14. ollski
    ollski
    8 Oct 2003
    5,991
    Thanks Received:
    225
    Birmingham
    Country:
  15. ianmcd
    ianmcd
    15 Aug 2010
    14,120
    Thanks Received:
    4,606
    Lanarkshire
    Country:
    Most of this information should not be shared on an open forum
  16. simond
    simond
    26 Oct 2004
    5,232
    Thanks Received:
    465
    Surrey
    Country:
    It was 7 years ago
    • Like Like x 1
  17. Agile
    Agile
    26 Jun 2004
    63,560
    Thanks Received:
    4,511
    London
    Country:
    People have been sent down for murders they did over 20 years ago.
Loading...
Share This Page
