FAO people with Hilmor Pipe Benders
18 Nov 2007
I thought this would be more relevant with the plumbing contingent so thought I'd post in here.
Just a quick question, I picked up one of these Hilmor GLM pipe benders:
http://www.screwfix.com/prods/63880...r;jsessionid=F0ZTS5TISI5SYCSTHZOCFGA?ts=59367
They are very good benders, however I just want to confirm that the formers you use are all flat on the back rather than having a groove? Can people confirm?
Cheers!
Back of the formers are flat, pipe side are 'grooved' to fit the copper tube.
I think he means a groove on the back of the former, the Rothenberger ones
(I think) have a V shaped groove running the full length of the former.
I thought they should be flat. The ones I used before had grooves in them but were Rothenberger ones and Record ones. Just wanted to double check!
I have to admit these Hilmor ones are much better than the Rothenbergers, which seems surprising since they are more expensive!
Cheers!
Must say That its confusing me to
how are they better they both bend pipes dont they?
Well even the cheapest Screwfix benders will bend pipes :P :wink:
The rothenbergers I used kept kinking the pipe, the Hilmors gave perfect bends every time. Could be a duff pair I was using but even my tutor used to say he much preferred Hilmor's than anything else.
had em all over the years
could not say which I liked best, all pretty much of a muchness really
my hilmor guides have the grove in the back. Usually if they start to ripple the pipe you need to lubricate the roller bearing. Unless your pipe is below about 5 degree celcius then it is likely to ripple every time
