Fascia oil based paint
28 Jan 2005
London
After cutting out 10 inches of fascia that had rot damage, I'm ready to put the replacement bit in. I've painted it all around once with Zinser primer and once with Albany undercoat.
Is there any downside to leaving the 'inside' without the gloss top coat and screw this bit on followed by a top coat for the lot?
I know insides aren't painted normally but the builder that put this extension up was a right cowboy who bodged it up so that every time there's more than a drizzle/shower, water gets in at the is corner. Correcting the underlying problem will need at the very least redoing the flat roof plus additional work at £1000+; not really an option here.
I would just give it extra coats of undercoat before fixing. As its not getting any direct weather it should be fine.
