Morning all,
My friend has asked me to have a look at a double-socket. He recons that when he plugs the dishwasher in, the RCD trips. Also, there are signs of heat damage (black) on the socket. So, it could be the dishwasher with a leakage current or a loose connection in the socket.
What is the best way to approach this? I think I should:
1. Plug the D/W into another socket using an extension. If the RCD trips, the problem is with the D/W.
2. If the RCD does not trip above then change-out the socket.
Any other suggestions?
...Also, I only have a multimeter. If there is a leakage current in the D/W, would testing resistance across L/E and N/E (at the plug) show less than Infinity?
Thanks,
Alex
Thanks,
Alex
