I am having an electrical problem in a flat I am doing up.
(don't know much about electrics, so the cause might be trivial!)
A few days ago, a circuit breaker tripped (probably because of overloading -- I was using a steam stripper at the time!). I switched the breaker back on and everything seemed fine.
More recently however, I realised that the ceiling lights are dead in at least 2 rooms (the sockets in those rooms are working though, and also I don't know about the ceiling lights in the other rooms as I have removed the lamps, taking care that no wires are touching!). Also 4 sockets are now dead in the room where I was using the steam stripper (however, I had been steam stripping for another few days after the tripping occurred). Strangely enough, 1 socket in that same room is live.
At the same time, once the wallpaper was removed from the wall, a massive hole appeared in the wall revealing 2 severed cables. However, they are not the same material/content. One is hard and has 3 wires in it: beige, red, blue. The other one is made of a softer material and has only 2 wires: red and black.
See image below:
Any ideas whether these weird cables have anything to do with my problem? (Or were they just dead in the wall and unused anyway?)
What else could be causing this problem and what can I do?
Thanks for any help..
See image below:
