I have a 5” fluorescent light installed in my shed, it has an electronic ballast. Last night I was out in my shed and the light suddenly went off. I flicked the switch off then on and it came back on – this then happened a further 4 times. I noticed that the longer I left it off for, the longer it stayed on again – could this be something to do with heat? The light is a sealed type which can be used outside. I checked the input supply and this was 230V after the light had gone off. I think the tube is a 1.5m T8.
What should I check to fix this fault?
