Hello,
Ok, I know this is supposed to be a home electronics forum but I just can’t find an equivalent forum for car questions… So my apologises if this is against the rules. However, I know you chaps know your stuff. So may be you can help?
My car is currently playing up. It’s an N-reg rover 218 (don’t tease me… it may not be sporty but it does it’s intended job). Recently the fuel and water temperature gauge have been playing up.
They both work fine with the head lights off. However, when I switch the lights on then the fuel gauge gives a constant high reading and the water temp gauge intermittently fluctuates about a much higher reading.
I’m not sure if it’s relevant but with the ignition turned on, but the engine not running, the fuel gauge reads zero with the lights off but max with the lights on.
All very odd. Any help would be appreciated.
