I have a fully-pumped gas CH system with two-port valves serving the hot water and radiators. It is quite elderly yet the original HW valve still works perfectly. The CH valve (controlled by a modern programmer and roomstat) has, in the last four years, been replaced THREE TIMES! Each time, there was a live supply at the junction box terminal block, but no movement in the actuator. Manually opening the actuator switched on the heating ok, but releasing it immediately switched it off again as the actuator sprung closed. Fitting a replacement actuator immediately solved the problem.
Why am I going through so many actuators?
