Came across this and currently in dispute with occupier over its acceptability.
16A MCB in shed CU supplying radial in 2.5mm2 singles in conduit for power. Power sockets are two DSSO one fed from the other - daisy chained or spurred off a spur.
My view is that if you are going to spur off a spur then there should be a 13A FCU before the first DSSO to limit the total as converting to a ring is difficult with the number of singles already in the conduit.
Occupiers view is that I'm looking for work and that as the radial is on a 16A MCB the cable can take 16A so what's the problem. Can see his point but I like to do things correctly. Am I being too pedantic?
