Sorry - this makes no sense.Cheers, just makes it easier to replace the appliance instead of using t&e
It's no different from or more difficult than having enough cable to be able to connect up a light switch or a socket....I have, I'm thinking in advance - the design of the flex outlet plate i'm using (marbo) would mean leaving a length of t&e available so you can actually get to the terminals to wire the appliance in.
Appliance flex would push up a straight, 50cm-or-so run of conduit with no problems.fishing for the wire etc.
If you find putting T/E into the screw terminals of flush accessories so tricky that you are prepared to go to those lengths to avoid it, maybe electrical installation work is not for you.Strip out the innards, attach wago (27p each) to t&e, attach flex to plate with cord grip then press and insert the stripped flex, attach plate to wall.
