Featheredge fence - cover posts or not?
18 Apr 2013
Hampshire
As you may be aware there are 2 styles to putting up these fences
1) Where the posts are visible
http://www.leytonfencing.co.uk/img/products/jacksons_feather_edge_fence.jpg
2) where the posts are completley covered up
http://www.kebur.co.uk/cms_uploads/images/FE18G.jpg
I am doing a job where the posts will be slightly uneven distances apart so it might look nicer doing method 2 - but for some reason I feel like I should go for method one - purely on the basis that it would make access the posts easier - for example if I needed to take down specific parts I could take down a section between posts - whereas if I use mehtod 2 I would have to take off potentially a huge part of the fence (if that makes sense)
any thoughts?
29 Sep 2009
Glasgow
I think it looks better without any gaps. You could use screws for the boards next to the posts so they can be removed if required.
18 Apr 2013
Hampshire
Its been a while since I did my last featheredge fence and I haven't got to the stage of nailing them in - but IIRC you don't overlap them do you?
I am just trying to work out how you would remove individual panels if they were screwed on - wouldn't the enxt board be in the way? or coudl you sort of slide it out as long as you dont put the same screw into 2 board?
