Featheredge fence - cover posts or not?
18 Apr 2013
Hampshire
As you may be aware there are 2 styles to putting up these fences
1) Where the posts are visible
http://www.leytonfencing.co.uk/img/products/jacksons_feather_edge_fence.jpg
2) where the posts are completley covered up
http://www.kebur.co.uk/cms_uploads/images/FE18G.jpg
I am doing a job where the posts will be slightly uneven distances apart so it might look nicer doing method 2 - but for some reason I feel like I should go for method one - purely on the basis that it would make access the posts easier - for example if I needed to take down specific parts I could take down a section between posts - whereas if I use mehtod 2 I would have to take off potentially a huge part of the fence (if that makes sense)
any thoughts?
I think it looks better without any gaps. You could use screws for the boards next to the posts so they can be removed if required.
Its been a while since I did my last featheredge fence and I haven't got to the stage of nailing them in - but IIRC you don't overlap them do you?
I am just trying to work out how you would remove individual panels if they were screwed on - wouldn't the enxt board be in the way? or coudl you sort of slide it out as long as you dont put the same screw into 2 board?
