Feeder tank on Pulsacoil 2000
They recommend 1 litre in store that only contains water and small F&E tank.
Have you been on the red wine with Agile?
1. Who is "They"?
2. In what document have you found that they (sic.) "recommend 1 litre"?
3. 1 litre of what?
4. For what purpose?
1. Who is "They"?
Should be "Who "are" they? They arev Geldhill who make it.
Instructions.
3. 1 litre of what?
Inhibitor.
To prevent corrosion.
There you are. Simple wasn't it?
1. Who is "They"?
No it shouldn't.
Gledhill is a manufacturer - singular, not plural.
Notwithstanding that, Gledhill doesn't recommend adding an inhibitor to a Pulsacoil 2000.
Instructions.
Not in any instructions for the Pulsacoil 2000 you haven't. :roll:
To prevent corrosion of what? Why would anything be corroding?
The simple fact is that you're wrong.
This is all well and good but you guys are getting too technical for me.
What would happen if my mum did not check the water level and the water totally evaporated.
Hm. Interesting question.
If the level dropped below the top of the cylinder, then it would probably merely get a bit noisy.
If the level dropped below the overheat sensor (if it still has an active one, because many have been bypassed), then there would be a risk of the water boiling.
If the level dropped below the top element, then that element would probably overheat and go faulty in a burny/melty kind of way.
If the level dropped below the primary flow take off, then the pump would bugger itself. At this point you'd probably notice that the water coming out of the hot taps is cold.
If you didn't notice, and the level dropped below the bottom element, then that element would probably overheat and go faulty in a burny/melty kind of way.
If you didn't notice the smell at this point, then nothing else would happen.
So you say "who is they".
No. I didn't.
1. Who is "They"?
... which is grammatically correct.
________________
You say that you've read the requirement to add an inhibitor in the "instructions", but there's no such requirements in the Pulsacoil 2000 instructions.
You say that an inhibitor will prevent corrosion, but you've neglected to explain what you think would corrode if a dose of inhibitor weren't added.
and you are just as i was brought up to call them a doylem :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
