I'm trying to find the relevant part of the 18th edition about where in a property the AC of a PV inverter can be fed into.
As a smallholding we have a brick built stable that has a roof that is great for solar panels, but it is currently at the end of a chain of CU's. Currently it goes:
Smart Meter -> Main CU -> Laundry room CU (external building) -> Stable CU (different external building).
Obviously the rating of the breakers and cables between the CU's will be a factor, but for sake of argument assume they exceed the peak PV internet output.
Will the internet be able to feed power into the Stable's CU, or will we need to have a cable run back to the Main CU? Running it back to the main cu will be a pain as it will need drilling out channels in the concrete yard, going under/over sewage/storm water pipes, oil pipes and water pipes.
If anyone knows the answer and can point me to the relevent part of the regs that would be fab.
