Thanks.The bath is plastic and upstairs
So, the bath cannot be earthed - nor bonded.
The pipes underneath could be.
However, your CU has all the circuits protected by RCD so it is likely, with a couple of provisos, that no bonding is required* to the pipes under the bath.
There is definitely no reason to connect a green&yellow cable from the pipes to the Main Earthing Terminal (adjacent the meter) downstairs.
Edit - * As far as the regulations are concerned.
