I'm not really much of an electician in fact I'm not an electician at all.
My electric shower died on me, The thing was old and came with the lemhouse I bought 6 months ago. The thing was from the 70's and dort of knowing my way around electrics on a basic level I went to B&Q and bought a brand new 9.5kw shower.
A couple of weeks after I installed it I started to notice that tell tale fishy smell from the isolator switch after I had a shower.
I removed the fuse and opened up the box and sure enough the live wire on the supply side of the switch had started to melt and the part of the switch it was connected to also was blackening.
The live wire appeared o be loose in the switch so I thought that may have been the problem so I replace the switch and made sure all connections were tight and sure and ran some juice through it for about 5 minutes by running the shower.
I checked the unit and the wires afterwards, there was that faint smell again, at first I thought this was resdual from before but with the power off I checked the live wires by touching them individual and again there seened to be some heat.
The wires on both supply and load are "Twin Earth" 6.0mm Max Rating 240v 47amps.
The question is, is a little bit of heat normal, if not what could I be doing wrong, is it the wiring, the appliance or the fuse in the fuse box.
The fuse I believe is 32amps the markings on it are.
B32 - 32A
B32 - 32A
