Fencing on sloping site
19 Apr 2005
I have to replace approx 70ft straight line fencing on sloping site (not steep). Which would be easier to erect closeboard or panels? If closeboard is there any disadvantage to using crossrails butted to the posts instead of arris and therefore make it easier to follow the line of the slope?
I would use concrete post and gravel board and step it down every panel depending on your slope. The reason for having panel is that you can replace it if damaged or rotted. You can make a closeboard panel to slot into the concrete post.
Panels would be quicker but every panel would have to be steped down the slope, use wood posts as they look better if the step down of the pannel is a big one.
Closeboard doesnt need stepping down at each bay if on a gentle slope, they would follow the contour of the ground better, use arris rails they will need a little trimming to fit the slots due to the drop down to next post, same for the gravel boards they will need the angle of the drop cut to each end.
Don't forget if you use panels you may need to use over length posts due to the slope.
____________________
Moderator, see Item 10a :wink:
