Fencing Problem
28 Jul 2010
Glasgow
My back garden runs on a slight slope.
The fence at the bottom (or top as it runs downhill!) of the garden is needing replaced.
I have bought new fence panels and will use 3 of the 4 existing uprights and replace one damaged one.
I have noticed that there is a lot of mud pushing against the bottom of the old panels which has resulted in them breaking.
I have shoveled as much away ahead of inserting new panels but I'm sure I'll have the same problem down the line. In removing the dirt I've noticed a lot of rocks/slates which previous owner must have tried to use as a deterrent but has added to the weight pushing on the panels.
If anyone has had a similar issue it would be great to find out how you got round it!
Cheers,
[/b]
have you considered using concrete posts and gravel boards? They are usually a foot high but you can stack them on top of each other to make it higher if needed.
I would definitely consider using a concrete post system as it is far Superior than using timber posts - the posts won't rot or snap off in gales unlike ordinary timber ones - I take it that's whats happened to one of yours.
I have recently replaced the fence at the end of my garden:
As for the corners, I opted to use 4"x4" timber posts (not the commonly used 3"x3" ones) for the corners because although concrete corner posts are available, they cost about £30 each and are extremely heavy.
The gate and trellis was reused from the old fence to keep costs down.
Anyway wish you well on your project - hopefully you'll be working in the shade :)
