Fencing
  • Thread starter Thread starter AI
  • Start date Start date
AI
15 Feb 2010
London
I have a chain link fencing with Concrete posts ready drilled for use. I would like to chainge this fencing to timber panel fencing to keep my privacy and security. The concrete posts are firmly on the ground, some of them about 3.3m apart. But these posts are wider at the base and narrow at the top. Instead of replacing them I thought it would be easier and cheaper to keep them. Can I use this concrete posts with timber panel fencing? How would the installation work? I look forward to your advice.
Regards
AI
heeelllooo and welcome A1 :D :D :D
as long as your shure you are allowed a fence and assuming its at the front the maximum height is 1m/4ft without planning permission
and its a non starter to use the old posts first because they wont be secure enough or because a fence panel is 1.828mm so your posts will just get in the way
if you wanted to keep the posts you could use closeboard fencing, which is stronger and attach the posts to the concrete posts. The closebaord can be altered to suit teh spacing of the posts. Personally though i wouldnt do it for a customer and would advise them to get rid of the posts and use new. You will also losde some of the garden as the new posts will sit forward of the old posts if you keep them
many thanks for your prompt replies. If I was going to get rid of the concrete posts, how long does it typical take to build a new timber fence. As I am replacing an existing fence I assume i don't need planning permission.
Regards
AI
if you are not bordering a highway then you can go up to 6 foot 6 inches. It really depends on how long teh fence is, the type of fence and the ground conditions to say how long it takes. Also depends if its a decent fencer doing it, a cowboy or a diy job!
if there are other houses the same round about see what they have done
if its ex local authority you may be restricted on what you can do
some only allow open fencing[see through]
