Firstly does anyone know of anywhere that can supply 35mm downlighters in satin chrome? I normally use TLC and they have the 50mm satin chrome ones which I have used in other places, but not the 35mm ones. In my hallway due to joist position I can't put them in centrteline so I'm fitting four and want to use the smaller 35mm ones.
Secondly transformers, I have only ever used the method of cheap transformers for each downlight, would it be better for me to use one transformer to power all four donwlights? If so what do people suggest? I'll have 4 x 35mm/20W lamps in one part of the hallyway and a single 50mm 35W in the other lower part of the hallway, maybe 50W depending on how the light looks once they're on. All switched from a std toggle switch, no dimmer.
Finally, I always look at low voltage downlights, but what are the pro's & con's of ELV vs LV? Am I right to always go with the ELV lighting or should I consider mains where ELV isn't necessary? I haven't really looked into the cost difference, but was thinking along the lines of reliability, etc.
