Is it ok to change a single panel radiator for a smaller double panel radiator?
I'm pulling mu ceiling down in my living room, I'm going to run my central heating pipes in the ceiling (and reposition my radiator) the pipes will be coming down the next corner, i plan on using plastic 22mm pipe, I'm guessing 22mm is the internal diameter so would a 25mm hole be big enough? I will be getting a pro in to connect it up and do pressure checks ect, ill just be drilling my joists and fitting pipes to try and keep the price down abit.
