Filled Travertine - Impregnating / sealing
28 Nov 2005
Gloucestershire
Just finished laying filled/honed travertine tiles. The instructions on the impregnator / sealer say one coat before grouting and one coat after. Remove any excess that has not soaked in after 5 mins
I did a few tiles to test ......felt like I was removing all I applied after 5 mins. The tiles do not look porous or appear to need sealing. I guess this is because they have resin floated across them? Can't tell any difference after treatment. Second coat will be the same or even less effective?
Advice / comments please
Hi Jedi,
id be surprised if they dont need sealing.The impregnating sealer will sit just in the surface of tile not on it as a surface sealer would.Have you tested the tile by putting water on it to see if it stains??
id seal as instructions,what have you to loose??
the second coat after grouting will also seal the grout protecting that aswell.
Thanks Sticky ... I'll do a 'water test' over the weekend ..... see if there is any difference. If there isn't I might skip the pre grout treatment and do one afterwards
for a novice I would say ...
seal/ fix/ seal/ grout/ seal
for sealer I always used
Aquamix Sealers Choice 15 Gold
