Hello I am after some advice. Unfortunatly I have had to use some filler on my walls. I just want to know about sanding down the filler and how smooth does it need to be?
I know this probably sounds silly but I have sanded and sanded and the filler is smooth and even but when I run my fingers along it you can feel a very slight bump when going from the wall to the filler. I am using fine filler and fine sandpaper. If i sand lightly nothing happens and if i go to hard it rips chunks of filler out.
Now I will be using 2 coats of builders trade matt and 2 coats of dulux matt.
Sorry if this is a stupd question but i havent really used filler before.
Many thanks
Many thanks
