We've had a couple of rats get into the floor cavities in our house, and I'm trying to work out how to block of the hole that is giving them access, which unfortunately isn't that easy.
We have an internal soil pipe that is boxed off and comes down behind some kitchen units. If I pull the units back there is an access hole into the boxed off section where I can see that there seems to be a largish gap in the floor.
I need to fill this hole really as I'm pretty sure this is where the rats are getting in. This is complicated by a few things:
1) The access I have to get to the hole is quite small, and there are a few obstructions including the soil pipe itself.
2) The hole I'm trying to fill covers quite a large area, running into the wall behind the soil pipe. The furthest point from access I have is quite far away, probably nearly 60cm.
3) There are some plastic pipes running just above the hole. I don't want to encase these in concrete really, so I need to be careful to only just reach below their level.
Ideally what I need is some sort of very thin (runny) concrete like substance that I can squirt in from my access point and it will then easily spread out to reach the furthest point away from my access point, but still set solid of course.
I don't have any experience with any self leveling compounds or anything like that, but I get the impression that most of these work on the basis that they are applied fairly evenly in the first place. This isn't something I will be able to do.
My only other alternative is to come at it from the other side and knock a fairly large hole in the wall to get better access, but this is far from ideal.
Any help or suggestions would be gratefully received. My wife is getting very stressed about our current unwanted guest!
Thanks,
Steve
Thanks,
Steve
