Hi all,
I have had my kitchen rewired before I installed the new kitchen.
The CU is in the attached garage the otherside of the kitchen. The electricians drilled through the cavity wall to the landing above the kitchen to run the wires under the floor boards and then down to the kitchen.
The hole in ther garage side I have filled with morter but the inside is difficult to get to unless I take the floor board near the wall up too. Is there anything I can use to fill the holes under the floor that the cables come through? I can just about reach it from arms length, but would be best if I could use a gun of some sort.
I wasn't sure if silicone or expanding foam would react with the pvc of the cable.
Appriciate any suggestions.
Ads
Ads
