    Dismiss Notice
Filling gaps around soil pipe
Discussion in 'Plumbing and Central Heating' started by DeusXM, 29 Jul 2019.
  1. DeusXM
    DeusXM
    29 Jul 2019
    38
    Thanks Received:
    3
    Country:
    I've moved into a property and after an unfortunate encounter with a very large and fast moving arachnids, I've discovered there's a gap in the bathroom that needs filling.
    I think unwanted guests are coming through the gap. What's the quickest and easiest way to fill it? Would expanding foam do the job and be safe to use around a soil pipe?
  2. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,376
    Thanks Received:
    1,734
    Northamptonshire
    Country:
    Not pretty but it'll do the job.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. DeusXM
    DeusXM
    29 Jul 2019
    38
    Thanks Received:
    3
    Country:
    Cheers.
    What would be a 'prettier' way?
  5. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,376
    Thanks Received:
    1,734
    Northamptonshire
    Country:
    Using a propriety filler, e.g. Polyfilla, which can be sanded smooth when dry. Expanding foam will do the job but may be more awkward to trim up in that situation. If you can, fill with expanding foam, so the stuff is shy of the surface by 1/2 inch or so and make good with filler.
    • Thanks Thanks x 1
  6. Sponsored Links
  7. DeusXM
    DeusXM
    29 Jul 2019
    38
    Thanks Received:
    3
    Country:
    Thank you, that's really helpful. Much appreciated!
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
