Hi all,
I am installing a solid fuel stove in my conservatory and because I do not have a chimney, I will be knocking a hole through the cavity wall (twin 4" block) and putting in a double walled insulated flue. The flue will be exiting the stove at the rear and going through the wall at a 45 degree angle. My queries are as follows:
1. What is the best way to fill in around the flue once in place. The existing wall is finished with a smooth sand/cement plaster finish on the external wall.
2. Do I need to take precautions to stop moisture gaining entry along the smooth wall of the flue?
Thanks in advance for any advice.
