Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
hi. i was wondering . on a filling loop is any there way of telling if the non return valve is passing by besides disconnecting it and having a flood. is there a test screw which can loosened? thannks
Why would you suspect its passing? Even if it was, you need still need the isolation valve to fail and the system pressure to raise above the incoming mains pressure before anything of any slight concern to happen...
