Hi!
Can i fit the 7.5 mm cable with unsheathed earth built in ,directly behind the shower control unit through the wall directly to the 45 amp doublepole switch?
The switch is located on the opposite side of the wall in the airing cupboard to which where the shower is located.
I intend to drill directly behind the shower contol unit through the wall.So no cable will be exposed in the bathroom. Is this ok?
As for the rest of the fitting,fuse box wiring from the metal switch box,has been carried out professionally.
And the plumbing has been completed
For the record,its a Gainsborough RE 600
Any Advice is appriaciated.
