- Joined
- 28 Jul 2017
- Messages
- 8
- Reaction score
- 0
- Country
I have a wall and ceiling to finish in my bedroom. I'm fixing up after a chimney removal.
I can put a piece of plasterboard in the hole in the ceiling but the wall is a bit more complicated.
From the sample quotes I've seen online I can't afford a professional so I have been thinking of dot and daubing it myself.
The issue I have is where the chimney was there is now an uneven surfaced alcove.
There's a patch of wall either side that should be fairly straight forward to plasterboard but I'm unsure of the best thing to do with the recessed portion.
Having lost a layer of brick (the chimney breast) I may need to think about noise reduction. I've found some acoustic plasterboard so I was going to put one of those in the recess and regualr boards either side.
Has anyone any advice on how I should level up the old chimey back area?
Should I hardwall it then dot an daub onto that?
I will be hanging a radiator on that area of wall eventually so whatever I do needs to be able to support one.
Also once the boards are (hopefully) in place, I reckon I would make a pretty crap plasterer
and my house is small and in a state at the moment as I'm fixing it up so I was wondering if anyone has tried skimming with ready mix skim? Or is there a decorating solution better suited?
Thanks in advance.
Thanks in advance.
