    Dismiss Notice
Fire Door stop size
Discussion in 'Building Regulations and Planning Permission' started by Jindigo, 20 Oct 2020.
  1. Jindigo
    Jindigo
    14 Oct 2020
    17
    Thanks Received:
    Country:
    Hi. Is there a bare minimum for a FD30 fire door stop. Is it 25mm or can this be reduced?
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    70,404
    Thanks Received:
    3,977
    Crossgates
    Country:
    Cook Islands
    You may get a better informed answer, but last time I got some, I looked it up and took advice, and the bigger stop is not needed if you have the intumescent strips with brush. These are easy to fit if you have a new door lining, difficult otherwise.
    I don't know if the brush is essential. It is also good for blocking draughts and noise.
    There is a Document which I don't have to hand.
    • Thanks Thanks x 1
  4. Jindigo
    Jindigo
    14 Oct 2020
    17
    Thanks Received:
    Country:
    Thanks that's the info I have gleaned from various sourced. Just trying to maximise the clear opening. The doors in question are flat entry doors with the seals and brushes.
  5. Nakajo
    Nakajo
    5 Dec 2014
    2,011
    Thanks Received:
    178
    Berkshire
    Country:
    12mm thick x 25mm deep
    • Thanks Thanks x 1
  6. frutbunn
    frutbunn
    22 Jun 2020
    837
    Thanks Received:
    155
    Country:
    If memory serves me correct the 25mm deep stop is a throwback from the original British Standard for fire doors from 1947ish(?), which gave very specific methods of construction of the door and frame rather than a method of testing.
    Its subsequently been found to be unnecessary and again if my memory is correct, I believe it has been found to actually increase the passage of cold smoke by helping to "draw" the smoke through the frame.
    For information a door designated FD30 does not require cold smoke (brushes) seals, and in fact in some cases should not be fitted, ie protected domestic stairs where there is no detection in the rooms opening onto the stairway.
  7. Sponsored Links
  8. Jindigo
    Jindigo
    14 Oct 2020
    17
    Thanks Received:
    Country:
    Thanks for this.
    Can we reduce to 12mm if we only have intumescent strip? Fire doors inside the flat?
  9. frutbunn
    frutbunn
    22 Jun 2020
    837
    Thanks Received:
    155
    Country:
    Assuming an FD30 is required then this will be OK to the internal doors.
  10. Jindigo
    Jindigo
    14 Oct 2020
    17
    Thanks Received:
    Country:
    Thanks!
  11. Nakajo
    Nakajo
    5 Dec 2014
    2,011
    Thanks Received:
    178
    Berkshire
    Country:
    Well that's 1 hour of CPD right there. Good to know.
  12. ^woody^
    ^woody^
    3 Sep 2006
    32,294
    Thanks Received:
    4,374
    West Mids
    Country:
    Depends if its plant on or routed in the timber
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
