As a trainer in fire safety I have some simple advise:
You don't need a "Gas" extinguisher just know where the Gas shut off valve is
Fire Blankets are a waste of time
Buy a "kidde" branded fire extinguisher fire from B&Q for about £15 you need a Class A, B, C, (these are the different types of fire it will put out) Ideally if you see a number next to the "A" even better the higher the number the more it will put out normal range is from 5-13
hope this makes sense
Also if you contact your local fire brigade they will carry out a FREE home safety check and install a 10 year Smoke Detector FREE of Charge!!
