    Dismiss Notice
Fire Regs (the duplicate has now been locked)
Discussion in 'Building Regulations and Planning Permission' started by hard-work, 14 Jul 2016.
Thread Status:
Not open for further replies.
  1. hard-work
    hard-work
    14 Jul 2016
    2,056
    Thanks Received:
    50
    Country:
    This is a one bedroomed purpose built flat. It has one living room, one bedroom, one kitchen, one hall and one bathroom. The aim is to remove the door between the kitchen and hallway and widen the opening by about 18 inches to make it all one walk in space. I was told by a builder that it still needs a door between the hall and kitchen for fire reasons, while another said there is no need. Does anyone know what the regs are in this situation.
  2. Sponsored Links
  3. ^woody^
    ^woody^
    3 Sep 2006
    32,768
    Thanks Received:
    4,428
    West Mids
    Country:
    The first builder is correct
  4. hard-work
    hard-work
    14 Jul 2016
    2,056
    Thanks Received:
    50
    Country:
    Thanks Woody. I could not find anything on the web in the regs regarding this point. Could you point to a web site or link?
  5. endecotp
    endecotp
    2 Dec 2013
    3,936
    Thanks Received:
    507
    Country:
    What country are you in? (E,W,S,NI have different rules, though none will allow what you want without some significant extra work, e.g. perhaps sprinklers, IIRC.)
  6. hard-work
    hard-work
    14 Jul 2016
    2,056
    Thanks Received:
    50
    Country:
    I am in London. Smoke alarm in hall and heat alarm in kitchen. I have seen open plan places.
  7. endecotp
    endecotp
    2 Dec 2013
    3,936
    Thanks Received:
    507
    Country:
  8. endecotp
    endecotp
    2 Dec 2013
    3,936
    Thanks Received:
    507
    Country:
    How far above ground level is it?
  9. hard-work
    hard-work
    14 Jul 2016
    2,056
    Thanks Received:
    50
    Country:
    6th floor. Kitchen window opens up onto a landing.
  10. Sponsored Links
  11. endecotp
    endecotp
    2 Dec 2013
    3,936
    Thanks Received:
    507
    Country:
    That high up, see section 2.13 of the document I linked to above.
  12. endecotp
    endecotp
    2 Dec 2013
    3,936
    Thanks Received:
    507
    Country:
    Note duplicate thread in "building regs" section.
  13. hard-work
    hard-work
    14 Jul 2016
    2,056
    Thanks Received:
    50
    Country:
    Thanks. I looked. I see nothing relating to my situation. In effect, as I have a landing running past the kitchen window, I must be classed a ground floor.
  14. hard-work
    hard-work
    14 Jul 2016
    2,056
    Thanks Received:
    50
    Country:
    Diagram 3 on page 23 appears to cover it. No hallway is shown.
  15. endecotp
    endecotp
    2 Dec 2013
    3,936
    Thanks Received:
    507
    Country:
    The regs do not make exceptions for flats where a landing runs past the kitchen window - and nor is there any rationale for them to do so. If there is a fire in your open-plan kitchen while you are in bed, the route from your bedroom to the exit will be full of smoke and flames. The kitchen window and its landing will not be any help to you in that case. Maybe you will be rescued through the bedroom window, if the fire brigade has a ladder long enough [they may not, or it my take a long time to arrive], or maybe you will BURN TO DEATH.
    • Like Like x 1
  16. garyo
    garyo
    11 Apr 2006
    2,110
    Thanks Received:
    196
    Berkshire
    Country:
    You remind me of a great sign I saw next to the railway a few years back "Maximum fine for trespass : £1000. Maximum penalty: Death"
  17. ^woody^
    ^woody^
    3 Sep 2006
    32,768
    Thanks Received:
    4,428
    West Mids
    Country:
    You can't look in today's regulations - although there are still regualtions for compartmentation, detection and and means of escape within Documenmt B (2). The rules that apply are the regualtions from the time it was built.
    You can't make the situation any worse, that's the principle. If there was a fire door there to start with, as there should normally be to have conformed the the regualtions when built, then you can't remove it, as then it wont conform.
    The options are to have an alternative means of either preventing fire and fire spread, early warning, or other means of escape. And this can only be decided using a risk-based assessment.
    And bear in mind that there are implications for the whole block, not just your flat. You could be personally responsible for anything that results from your altering of life-safety measures.
Loading...
Thread Status:
Share This Page
