- Joined
- 16 Dec 2023
- Messages
- 6
- Reaction score
- 0
- Country
I have a Firebird 120 Combi boiler and was recommended a Honeywell Home T6R smart thermostat by the local plumbing supplier so that I can fully control the boiler with a smart app and my Apple HomeKit.
The point of getting this smart thermostat was so that I may turn on and off BOTH the central heating and hot water systems wirelessly or using the timer in the smart thermostat. However, looking into how one is expected to use these smart thermostats with a combi boiler, it seems that the norm is that the hot water is just left on permanently, and the only system that is connected to the smart thermostat is the central heating. This is not what I wanted at all. The hot water system in the boiler can be turned on and off at the boiler, and the boilers internal hot water timer can be used to do this or overridden to constant on, or constant off. The central heating system in the boiler can also be turned on and off at the boiler, and the boilers internal central heating timer can be used to do this or overridden to constant on, or constant off. Like this:
As the hot water system uses and wastes oil (eg: while we are sleeping) so long as the system is switched on (as the system keeps a small amount of water hot all the time it is on), I want the smart thermostat to also turn on and off the hot water system with its timer, and allow me to override this switching using the smart thermostat app or my Apple HomeKit.
I then also want the smart thermostat to allow smart control of the central heating system as well.
Is this possible or would I need to return the smart thermostat because it cannot do what I want?
I attach a photo of the Honeywell Home T6R smart thermostat wiring diagram which shows the wiring for combo boilers as just using terminals A and B for central heating, with no provision for hot water switching using terminals D and E (which I want to use to turn on and off the hot water).
I do hope someone can help, and thank you.
