firing in a hydroflow
  • Thread starter Thread starter angelf
  • Start date Start date
A
angelf
How complicated is it to wire a hydroflow into a fused spur.
If there is no fused spur close by what is the alternative?
quick question because I'm too lazy to google, what's a hydroflow?
is it one of those mascerating toilets?
I think its one of those things you clamp to your water supply pipe which claims to remove limescale and anything else the manufacturer can think of that sounds bad for you.
Its a limescale prevention effort.
Only uses 1 or 2 watts, so 1mm flex to the fused spur.
Or put a plug on it.
Or don't bother connecting it at all - the results will probably be the same.
I thought it was one of those hot water tea boiler over sink jobbies you see in many offices, hence my question above.
I now realise these are a 'hydroboil' :oops:
