First fix
30 Oct 2012
Hi all
Quick question re new extension and first fix plumbing.
We are building a single story extension, with a sloped roof, there is a bathroom within this. I have fitted complete central heating systems before and quite comfortable with plumbing etc.
My questions is around where to run the pipes, are there any minimum requirements of heights etc. I think best place to run them is around the inside walls (50mm insulation also on inside so will cover well) builder suggested roof also an option, my concern is the roof could get very cold though of course insulated etc.
Is either fine?
There aren't any regulations concerning heights. The key things to consider are:
1. Run hot pipes above cold pipes, so the cold ones don't warm up.
2. Clip them properly at the recommended intervals.
3. Try to avoid any joins, other than soldered joints, in inaccessible places.
4. Pressure test everything that's going to be inaccessible before covering. Wet pressure testing is safer than dry, which can be dangerous.
5. Try to avoid places where later owners (or yourself in later years!) are likely to put nails / screws through the walls. If possible, use metal plates to cover where pipes run.
6. If running plastic pipe, wrap aluminium foil around it or run a long strip along it, so that metal detectors will still work.
