I am buying my first house and plan on re-visiting the property before exchange. I have a few questions, perhaps more than a few and would like some opinions/suggestions on what to look out for.
1. The survey pointed out the drains are partially blocked. Our conveyancer added this into enquiries and the seller replied that surface water builds up on the drive and soaks away, they are not blocked. Is this a reasonable response to accept and should I call for someone to check on my visit?
2. It also assumes the mains pipe may be of lead because of the age of the property, although I believe it would be covered with limescale. I am planning to have the water tested for lead concentration first. Is it worth the trouble of changing the pipe and how costly it could be?
3. The boiler was installed 4 yrs ago and I obtained a building's regulation compliance certificate from the seller. The certificate refers to the owner as the applicant and also the one who carried out the work (strange unless it just refers to the undertaker). I don't think of anything dodgy but should I call gas safe to confirm?
Most importantly, there is no gas certificate, but this does not mean it is not safe. Is there anything I should look out for or call a gas safe engineer to inspect?
4. The water is gravity fed from a tank in the loft and a cylinder in one of the bedrooms with a condensing boiler located in the kitchen. Generally the system looks fairly looked after but I don't know much about this layout, I've lived with combi boilers only. I am worried about the pressure and think of installing a pump, mainly for showers. I heard that I may need to change some pipes due to the pressure difference, but I haven't got much clue yet. I may also build a bathroom at the ground floor in the future. How costly would the plumbing be for this job (apart from the bathroom fitting work) and should I install pipes pro-actively to feed another shower right below the main bathroom?
Anything else to look out for gas/plumbing related?
Sorry for the massive post, you don't need to address all the questions but thanks for reading!
