Hi Folks,
I have a fishpond pump which also has a UV lamp. These two have been running for months without any problem and still don't have a problem. The odd thing is though, I installed a timer and whenever the timer cuts out, the RCD drops. Almost without fail this will happen.
I recently turned off the main power as I was working on something and when I turned it back on, the RCD was down again.
The timer is a simple SPDT relay which interrupts live. Neutral is always connected.
Once reset, everything is happy again.
The RCD is built into the double outside plug.
No amount of switching the plug on and off can reproduce this - only when power is cut.
Why would this happen? (Some sort of back-EMF from pump / CF tube?)
How can I stop it as the pump will not turn on again.
Cheers,
Crispin
Cheers,
Crispin
