Hello all, this is my first post to this forum so go easy!
I have a large hallway that has 3 switches to control the main light. I wanted to put a PIR switch in here so I bought an EcoSwitch (see here if you haven't seen one before), without realising that it wont work in a two way situation (without using 2 of them anyway!). After much scratching of head, I thought that instead of trying to replace one of the switches with it, maybe I should fix it to the ceiling near the rose, and just feed it the Live and Neutral from the light. This way, no matter where the 3 switches are, the PIR which is now in parallel with the switch circuit (a sort of master switch if you like) will complete the circuit and turn on the light. Am I correct in my thinking or am I just looking to end up a crispy critter at an early age?
TIA!
TIA!
