Today I fitted a punchbag bracket to my bedroom ceiling. I climbed into the loft to find the beam, which was probably 3 inches wide and then drilled through the artex into the joist, then I hammered in the plugs and screwed the bracket on. Whilst in the loft I screwed a board into the joist being used and also into the next one on the right, I also did the same to the left side but using a single thin plank and not a board, hopefully this will provide extra rigidity.
So I'm assuming I've done this correctly, will the bracket stay put now as I'm still a bit unsure if I start smacking the bag it'll fall out!
