Fitting a new socket
30 Jun 2007
Kent
Hi all
Im fitting a dishwasher and need to install a socket under the work top for it. When i removed a cupboard to make space for the washer ive found a roll of cable which i think the previous owner ( who was an electrcian) has wired up as a spur. The cable is taped up but is live when i tested it.When i switch off the fuse for the kitchen sockets it goes dead so i presume it is a spur.What i need to know is can i fix a socket myself or do i need to get an electrcian in? Im a competent DIYer who has a small knowledge of electrics, (i know the dangers of electrics and how circits work)
Many thanks
trace it back and see where it comes from.
I've traced back as far as i could and it seems to come from a socket. going by the thickness of the cable i asume it is a spur. And what fee to the council?
"re-fixing or replacing enclosures of existing installation components, where the circuit protective measures are unaffected"
is NOT notifiable.
So if there was a socket outlet there to begin with :wink:, which got damaged, you could replace it with a new one.
